AM getting ready for a trip to Tx tomorrow early afternoon from Va. TO night I was gjust going over double checking everything with the truck.
I had a code in AE. SO I turned off the truck and PULLED THE KEYS out of the ignition. I pulled the chip out of the PCM to see if the chip was the issue. I had AE still plugged into the OdBII port.
Well immediately on putting the key back into the ignition I got a PATS Security Engine Disabled Code.
All I can guess is the AE beign hooked up and the card pulled tripped the PATS.
Now I can not start the engine. I can also no longer connect to AE either. All normal for when PATs locks you out.
BAsically everything comes on including the glow plug module accept of course the fuel pumps etc.
How do I reenable or turn off the PATS?
Pull the batteries for a few hours what?
RIght now I feel so SCREWED!!!. Everyone is asleep expecting to wake up and get ready to go to TX for 2 weeks and I have a Excursion that will not start.
SO I could use some help ASAP PLEASE
Damn I hate when crap like this happens.
