Freerider15
So, just noticed a puddle under the truck. I just got done towing a trailer with a vehicle ~600 miles round trip this last weekend. I thought it might be the other issue I'm tracking down, coolant leaking somewhere on the front side of the engine.
Engine hasn't leaked a drop up until this point then BAM...both of these issues. The truck has ~135k on it, i've only put a few thousand miles on it in the two years I've owned it.
Specs on truck:
- 99.5 F-350 7.3L, ZF6, 135k on the ODO, pretty well stock.
Oil leak locations:
Back side of starter?
Main leak seems to be on the back passenger side of the oil pan (causing it to leak out the hole shown as well):
Bad leak...this came out in about 10 minutes of running:
My guess would be oil pan gasket? It doesn't leak at first, or after sitting for a bit. So that leads me to believe gasket since the sloshing of the oil is whats causing the leak.
Any ideas? I hate to see this since it means pulling the motor :'(
Specs on truck:
Oil leak locations:
