Need more HPO
powerSmokin
Marysville, Wa
Well I think you would have to find out the month and year the truck was made and call him up. He will steer you in the right direction.
JWaltz
Im running 225/100's and has anybody tried the deisel site high pressure oil delivery system in theory seems right ik these pumps push up to 6000 PSI.
Pizza pig
MD
Hybrid bodies and depending who built the injectors; remove a shim. Best bet is to add another hpop
Extended Power
Elite dual hpops or build your own kit using a hydraulic pump
Have these been proven on anyone's setup? Pictures are posted, a running engine video, but no comparisons per say. (without pump, with pump.)
I know I was curious what their setup was worth, and almost fell off the couch when I found out.
Hybrids would be the easiest solution...
Pizza pig
MD
Only problem with hybrids is the lack of icp in tuning. You can only go so far.
java
Texas
I think I need a HPOP, I'm only getting 1600 on my race tune. Is there an upgraded HPOP like on the 7.3?
kyle43335
Diesel site.
Dont let anyone tell you theyre junk. I found out that they need alittle tunning love and its running my 225s full tilt.
Kbryant777
Plainfield,IN
If you are going on a gauge using the obd 2 port you can't trust it. Most tuners fool it to we're it reads low. The only true way is to hook up a mechanical gauge.
