idkillinit
Ok guys I'm lost and confused. Im having a movement problem meaning I have none. The truck has no gears at all. Every gear is neutral. The issue here is that if I rev the **** out of it it will move in the direction it is supposed to meaning reversing goes backwards n drive goes forward. So far I've replaced 2 converters thinking I had bad enough luck to get a bad one from ford. I replaced 2 valve bodies a front pump and then I took it out again and rebuilt everything too to bottom. So after all that I just bit the bullet and bought a reman from Ford. Put it in filled fluids same ****ing thing. Idk what it coukd b now so if anyone has a idea im open for all. Thanks!!!
