Need to find a thread
BigJDW
Daytona Beach, FL
I'm looking for a thread about that talks about swapping rear ends, more specifically swapping new srw rear end into old drw truck. I know I've read something about this some were just cant find it. If any one know what im talking about can you point me in the right direction thanks.
Cat_rebel
Rebecca Black took my seat
Remove driveshaft, jack up & support truck with strong jack stands under frame. Remove shocks, remove sway bar (if you have one) Remove tires, unhook brake line at the T by removing axle vent. Remove U bolts with wrench/torch/cutoff wheel & lower axle onto cart or leave on floor & drag out. Re-install in reverse order.
BigJDW
Daytona Beach, FL
THANKS :slap:
Yes i tried search, IT SUCKS
I know how to do it.
But i thought there mounting problems when you take a rear end out of a super duty and put it into 95 drw.
Cat_rebel
Call Cary (OBSWIZ) he's the master at newer rear ends into OBS trucks. Unless you have a C&C axle a pickup axle to pickup axle should swap right over. You'll need a different U joint/yoke. You will also have to do the front as well or you won't be able to swap rims front to back.
