New Build
BBottoms
Buffalo, KY
What kind of EGTs did you see on the dyno? Stock pistons don't seem to like a lot of heat, but you're shoving a lot of air so the pistons might be relatively happy.
H&S squeezed over 1000 out of the Duramax stock bottom end. Surely a 6.4, that is known for a it's strong bottom end, will hold up to more, at least for a while... 2000+ ft-lbs is still a lot though! :hammer:
extreme3807
Bucyrus, OH
I dunno honestly. It has wayyyyy more left in it though.
I can't pull the compressor housing, so it's time for a little cab on painting lol
pog
psa
garbage bags work better.. cover way more area and use less tape lol
HD F250
Washington DC
Smart man, you listened to Dustin and used the self etching primer. Looks great and should not peel or flake with that primer.
