New front springs
Mwilbur516
Who knows where I can buy new front springs that would accomplish the same thing as stockers and 2.5" aluminum spacers. I currently have the spacers and stock springs. Id like to loose the spacers and do aftermarket lift springs only. I'm trying to decide what height I want. Id really like 4" higher than stock. I'll go ahead and get an adjustable trac bar as well. Would I need a drop pitman arm?
Any info is appreciated.
Sent from my BNTV400 using Tapatalk
ODAWG714
Orange*County, CA
Your better off just getting a 4 in kit complete, you will need to do the pitman arm/ track bar drop and springs and a re alignment. Also a 4in rear block to level the truck out
Mwilbur516
Thing is, I've already got the rear block, U-bolts and shocks. All I really need is the springs, trac bar and drop pitman arm.
Mwilbur516
Some said the stock pitman arm was sufficient for up to 4" of lift, but I have to doubt that.
Mwilbur516
ICON makes a 2.5in leveling kit that uses new springs. Maybe check that out??
I've got 2.5" spacers, just wanna go higher. I guess I could do new springs and still use the spacers..... I really thought someone made a set of 4" taller than stock coils for around $150. I swear I saw them somewhere a couple months ago, now I can't find them.
ODAWG714
Orange*County, CA
You can use your stock tracbar with a drop trac bar bracket.
Or icon makes a nice adjustable track bar to have a better quality bar.
I have 4in springs and a pitman arm if you want them.
Only thing you'll need is a trac bar bracket
Mwilbur516
How much do you want for the springs and pitman arm?
Sent while driving, drinking coffee and threatening to kill people in traffic.
Mwilbur516
I've been looking at the Icon and BD adjustable track bars.
HeavyAssault
Middle, VA
Running the old DR 4.5" kit with the TEI using the stock pitman arm and the ICON adjustable trac bar. NEVER needed an alignment.
I think there are a few people out selling used parts on the Classifieds or Craigs.
ODAWG714
Orange*County, CA
Matt I gotta see what parts I have in the garage I'll let you know later on.
You cannot go wrong with the icon bar, I beat the piss out of mine and it still holds up like when I first installed it
Mwilbur516
Take a look when you have time and let me know. I appreciate it.
I definitely want a new adjustable bar in case I go bigger in the future. Plus, it's just a better way than the drop bracket IMHO.
Chatham036
Matt - contact Jeremy at Pure Performance. He will be able to help you out
dieseljosh07
Georgia
I can get adjustable track bars from PMF. They don't have the springs you looking for listed separate from there lift kit but I'm sure they can be purchased separate.
Mwilbur516
Don't be shy, shoot me a price on the track bar!
Dlinzy
Once you go above 4.5" you have to do a # of things, drop steering stab bracket, pitman arm and stack a block in the rear with new u-bolts in addition to the adj. drag bar. Also extended sway bar end links F&R and SS brake lines.
+ you should know there is a huge difference in the drive-ability from 35's and 4" and 6" with 37's.
I did all of this in my journey to where i am today ICON 4.5" +2
spring spacer.
If had it to do over i would sell the 4.5" kit and buy ICON's 7" kit for just a bit more than i got in it now.
Denny
Mwilbur516
spring spacer.
Denny
That's why I'm staying at 4" of liftvand 35's. That's plenty. I've had trucks with lifts from 6" up to 10", no fun driving day to day.
At this point, I'm gonna wait and see what Odawg comes up with. If he finds a set of 4" springs and drop pitman arm laying around and we settle on a price, I'll go that route.
