New Intake Manifolds
Chrisf97305
Salem Or
Well after about 10 hours of cutting and grinding I have 1 intake base done. Here is what it looks like.
and bolted to the head. This should flow some air.
Magnum PD
VA
Your using ice cold water in that cooler then? Obviously no water leaks. Should be interesting though.
Chrisf97305
Salem Or
Just got the intercooler back with new elbows and V flange welded in.
The flange has a O-Ring in it to help seal.
It all works, I will be installing it over Thanksgiving.
907DAVE
AK
You'll be glad you went that route.
Do you plan on adding any additional supports to that cooler?
Might get heavy when its full of water.
Chrisf97305
Salem Or
YES IT DOES FIT
and here it is in the truck. Everything is still just tacked together. Now I know it fits and its time to burn it all together. That was the easy part. Its all the little things that takes forever.
Ya it is a little tight. But it fits.
Chrisf97305
Salem Or
I am running a air to air in the front of the truck. Its from a twin turbo mustang.
Thats how I am combining both turbos. The intercooler may look small but it's 4 inch thick and in the middle of the grill for good air flow.
The water to air is mostly for pulling when its hot, Not a lot of air flow at MPH.
Chrisf97305
Salem Or
This is what I came up with for my new fuel system.
I am happy that my front cover still fits.
And here is something different.
swamp_ratt
hudson, wi
yeah i seen that small air to air too. i was just curious as to how sufficient it would be. all the water to airs ive seen were a lot bigger, and that small of an air to air cant do that much can it?
Chrisf97305
Salem Or
When I specked out the coolers the # say It will. I don't tow with the truck, so I am not really worried about it. If that cooler is to small, I still have the bigger cooler that I had on it before, I could modify it and use it. Time will tell.
