New OBS headlights....
Binder man
Dumb question but how are these different than the ebay ones? I purchased them a year ago and was curious on the difference? They look the same in pics?
zilla68
Moore Oklahoma
whoever makes these lights needs to drill out the hole on the headlight that goes into the side trim piece by the fender more. I ended up cracking one of the bosses, and when i started looking, both my headlights had improperly drilled holes, the hole only went down about an 1/8 inch, causing the piece to crack.
Luckily I drilled the other side with no issues, but had to fix my new headlight before it was even installed.
other than that, everything fit fine, just those 2 damn holes.
FORD7.3
Glad I wasnt the only one that had that happen...
FORD7.3
Got the photo whore cleaned up figured Id get some pictures...
Truck4
Hey Paul how do you think the clears would look on mine? CC SWB white on top with light gray along the bottom pannels, as far as blubs do you just have to change the color for the turn signal or what? and can I go alittle bit brighter than stock? thanks for the help
Roy
