NEW S&B 83-1001 COLD SIDE INTERCOOLER PIPE PART# 83-1001
2017 superduty
Bend, OR
$175 plus shipping
Fixes blown hose problem for 2017-2026 Ford 6.7L engines. This pipe was an extra as my replacement intercooler came with its own piping kit.
The S&B 83-1001 Cold Side Intercooler Pipe is upgraded replacement for the burst or leaking intercooler tube in your 2017-2026 Ford 6.7L Powerstroke. The 3.50” diameter polished aluminum intercooler pipe is larger and less restrictive than the factory pipe. Less restriction means greater airflow, and improved airflow means better performance.
Maximum Performance
The S&B Cold Side Intercooler Pipe replaces the failure prone factory intercooler pipe that is known to fail, leaving you stranded.
More Airflow
The 3.50” diameter larger-than-stock polished aluminum intercooler pipe offers improved airflow. Greater airflow equals increased performance.
Better, Stronger Material
The 5-Ply Aramid Reinforced Silicone Hose is not only built to last but it is much stronger than the stock hose. Featuring heavy-duty 3/4" wide stainless-steel spring-loaded T-Bolt clamps and bridge.
Designed For Easy Installation
The silicone hose and two-piece intercooler pipe design makes for an easy installation. Check out the step by step installation video above.
CNC-Machined Aluminum
3/4" Wide Stainless-Steel Spring-Loaded T-Bolt Clamps
