New to 6oh
Strokersace
Towanda, KS
I'll be there the 21st if you are going to be around.
Yeah, I'm either leaving that night or the next morning to see family for Christmas.
I'll pm you my cell number. Could come snag you from the airport to save on a cab ride if you'd like.
powerstrokedkid87
New Jersey
if your doing studs:
studs/factory gaskets/stc fitting/fuel pressure spring update/egr delete/intake manifold gaskets/exhaust manifold gaskets/oil cooler/coolant flush &coolant filtration system/rocker box gaskets
if you not doing studs:
egr delete/oil cooler/stc update fitting/fuel pressure spring/coolant filter
just my thoughts
KBMKVIII
Texas
That sounds perfect. I will take you up on that offer. I'll call you when the day is getting closer.
KBMKVIII
Texas
just my thoughts
What's the deal with the oil cooler on these?
Fuel press spring? Like the bb mod? Sorry have no 6.0 part of the brain yet.
And sct update fitting? What's that?
Rocker box gasket?
KBMKVIII
Texas
ok i need a bundle price vendors... pm please.
fuel spring kit.
5" straight exh turbo back.
egr delete.
coolant filter.
and the sct will be getting ordered from matt asap
still deciding on where to get gauges.
will i need a turbo oring kit for when i do the egr delete?
KBMKVIII
Texas
well got the tuner from matt on the way along with the exhaust, coolant flilter, 6.4 banjos, blue fuel spring on the way. ill get crackin this weekend!
Kbryant777
Plainfield,IN
If you get gauges on it before you do studs check the temp difference between engine oil temp and engine coolant temp. You don't want them to be more then 15* apart. If so might as well do oil cooler too
Mixedbreed
Laramie, Wy
if your doing the STC upgrade, i have one siting in the truck unused. the dealer sold it to me when i did my HPOP, but i had already upgraded it when i did the studs/turbo/inj etc.. 40$ shipped
KBMKVIII
Texas
i have seen those numbers for the deltas here after doing some research.
as far as gauges those are on the way soon.
just doing a little price shopping.
i hope to excape doing studs for a few months. but thats just gambling.
