Nfab Prerunner Bumper with 20x12
c63 AMG
Guys I know there are 100x threads about "will this wheel fit"... But here's another with a little twist that I can't find an answer to.
2015 with:
2.5" level
20x12 -44
325 60/20 Toyo At2 (35.4 x 13)
Nfab Prerunner bumper
Since 20x12 usually rub on fender liner and stock bumper will I be ok with this setup?
Thanks and don't shoot me!
Sent from my banana using Tapatalk
still will have to deal with your inner fender and possibly the pinch weld.
c63 AMG
Thanks. So are you saying I would have to trim the actual fender? As in I need to cut and repaint or is this some "extra" support material on the inside of the fender?
My first diesel so I'm trying to learn and get it right the first time.
the inner fender is felt. pull it back with zip ties. If the tire then rubs the pinch weld on the bottom of the rear of the fender, you may have to make an angle cut on it.
c63 AMG
Awesome thanks for info.
c63 AMG
Regarding tires will I have an easier time with:
35x12.50/20 (34.5 x 12.52)
vs. what I want
325x60/20 (35.4 x 13)
Pretty big difference in the diameter with the tire size I would prefer. Most people seem to run 35x12.50 and I'm wondering if it's because they prefer the look or fitment is easier?
UNBROKEN
Add a 3 link up front to buy some more room at the fenders and you can easily run the larger tire.
