Coxey Diesel
What size jet is everybody running on one stage? The .074 jet I'm currently using doesn't clean my injectors like I would expect. I think my bottle pressure could be off as well.
bottle pressure is everything....
It varies. 900-950 usually
Really? That low?
I could only get it up to 800 with a hair dryer, gone to find a torch.
It depends on what you are doing with the truck and how the truck is setup. 950 will have a smaller pressure drop down the track but if you have stages and the ability to control the volume delivered than you can bring the pressure up to deliver a larger volume, and as the pressure drops, your additional stages kick in. The key is the transition from liquid to vapor and you need to stay at this psi. So I start just above it and as I travel down the track the pressure drops. Now we're in the psi range that delivers the dense volume I want. Starting at 925 will force you to drop real low at mid track and deliver a rich liquid (lower volume) in the intake. Pressure = volume but vapor is less dense so adjust to best suit your setup. I start at 1150 psi, purge at the line so now 1100 and finish at 975 to answer your question.
BTW: The dyno is a completely different setup.
