Nitrous setups...... Good brands? Pros/Cons of running nitrous
6 L chevy eater
Franklin, VA
dam i so jealous. lol
ima take the back and pass. seat out of mine next time i go to the track!
on my nitrous set up, two stage, i was spraying both right in the intake elbow, picked up 10mph off jus a single 93jet in the 1/4.
since talking with stone pusher and a few other guys i have welded bungs in my hot side pipe for both stages
that being said its not such a shock to the motor spraying it the hotside pipe, i have yet to spray both stages since the built motor, hoping toin the next couple weeks if i ever get my trans back.
too much nitrous at one time with enough fuel will bend rods
stonepusher
San Antonio
sorry to derail your thread but stonepusher what was your icp with warren 225/100 and a stock hpop?
With the 225/100's it dropped pretty good, I wanna say 3.5-3.8v. With the 285/150 hybrids it maintains 4.5v @ 1.75ms pw.
Is this on a stock bottom?
Yes stock bottom end, everything stock really except for studs, sticks, turbo, and reg return.
RSK
Connecticut
Wow! How much is nitrous here in the states?
2005 F250 6.0 powerstroke, 6 speed manual, egr delete, arp head studs, new oil cooler, aftermarket coolant filter, custom intake, 4" down pipe into dual 6" stacks, 8" lift, TSD super panty dropper tune.
$5/lb usually.
Mike@MPD
Pasadena,MD
Never had an issue in MD driving with the bottle connected with no tailgate. But here as long as it's not connected they don't care. I've always ran one big solenoid with two lines off of it and start small and build up until you get where you want or run out of fuel. Nx solenoids have done well
6 L chevy eater
Franklin, VA
what kind of jets were yall spraying on whitety back in the day
buschpoweredstroker
Upstate NY
I have a cheap ($500ish)zex system on my 03 7.3 pull truck, worked ok for a while but the controller that hooked into your tps wires for wot spray crapped out after a year or so. I wired it direct so the switch actuates the solenoid and it has worked fine ever since. I wouldn't recommend this for daily driving though. I am running 400/400's and supporting fuel/oil mods with a non wastegated, ported S482 and single stage 225 nozzle that I drilled to xxx, just not sure what the numbers are on it now, it's paper thin on the outside where it sits in the port. 250,xxx stock forged rod bottom end and I haven't bent or snapped a rod yet. as said before.... start small and see how much extra fuel you have and go up from there until you get to where you have a little smoke left at wot and full spray. It will start popping if you lean it out too much, but I don't recommend that test. Also as said before, get your r's up before spraying to avoid bending rods. Also, get a bottle heater to keep the bottle warm while spraying, and make sure you empty and ice the bottle for an hour or so before having it filled. You'll spray a full spray from 1100-900psi but below that I've noticed a difference and usually have it filled for the next pull. Usually get 3-4 pulls with the nozzle I have. I Pay $6/lb here in upstate NY but I think I'm going to buy my own fill station because I have to drive an hour each way to get bottles filled. Good luck...
