no pcm power
89 Stroker
Southern Cali
ever since i fixed my ground issue about 2 weeks ago my truck has been starting and running fine, today i drove it around, disconnected the batteries to clean the terminals , hook them back up now i am getting no WTS light and no response when i try to pull codes , all the fuses under the hood are good as iv checked twice now
89 Stroker
Southern Cali
re checked the fuses under the hood and they are good , all the big 60 amp, 30 amp ones and so one ere good, under the dash the ones i know have power to were working, i took out the big black relays under the hood and they get power to them , unless one of those ones control the pcm? the stuff in this truck was out of a 97 E350 van
Jomax
Arizona
Unplug your ICP sensor and try starting it. If it doesnt, next unplug your EBP sensor on the front of the motor and try to start.
Bugman
Gypsum, Co
I am not sure on which relay it is out of a van but there is a relay that controls the PCM power.
You might want to pull the PCM connector and verify that you have power on pin 97. I believe that the pins on the van are the same as they are on a pickup. Just wondering are you getting any other lights when your turn the key on?
  • PCM Printout PDF.pdf
89 Stroker
Southern Cali
I have power to the 97 pin , everything else is the same when I turn the key on , only thing that doesn't come on is the wts light for a bit,
89 Stroker
Southern Cali
Anyone else? Anyone have a picture or diagram showing where the 22 slot is? Iv triple checked all the fuses under the hood but would like to be sure I am in the right one
Bugman
Gypsum, Co
Your big problem is that you have a Frankenstein truck. Some van parts some pickup parts. That is where a lot may give you some information which will be wrong for one vehicle or the other.
Here is the Power Distribution Box for a pickup. I am not sure if it is the same for a van if that is indeed the fuse box that you have.
89 Stroker
Southern Cali
I hear that , this should be fun...
89 Stroker
Southern Cali
Here is a picture of the box under the hood , the 20 amp fuse for 22 or at least the only 20 amp fuse under the hood is still good
hogasm
I am in the same boat as we type. Sent off pcm thinking it was bad and it tested ok. If I find something I will post it here.
97 E350
89 Stroker
Southern Cali
Getting no smoke out of the exhaust , taken the ground off and cleaned them , checked all the fuses and they were good , re checked the pcm connector and am getting power to the 97 pin , I am lost
EDIT , just went out to ohm test a pin on the pcm connector and as i loosen it i hear the relay click on then click off, so i sit there and wiggle the connector back and forth and hear the relay click on and off so i found my problem...
Jomax
Arizona
Did you try spraying contact cleaner?
89 Stroker
Southern Cali
anyone have a possible fix for this? the connector is barley threaded in and it turns everything on , literally half a turn inward on the bolt and everything shuts back off , thread the bolt half a turn back out and everything turns back on,
Parker, TX
Try cleaning the contacts with some contact cleaner. I would disconnect both batteries before doing that as well. Check to make sure the connector pins are not able to push out the back of the connector. Cheers!
89 Stroker
Southern Cali
will go back out and try cleaning them again , and will double check the pins!
EDIT , re cleaned it, checked if anything was loose or moving around and nothing happened, seems if i push down on the bottom of the connector when its barley in, it works , if i go to bolt it in then its shuts back off
Jomax
Arizona
I think you need a new connector, that's going to be fun rewiring it...
