mstng5point0
So a little info its an 07 i just did head gaskets, studs, oil cooler, egr delete, stc fitting, updated stand pipes and dummy plugs all new gaskets from the heads up and new inj o rings. Filled up with rotella t6. Has a ficm by ficm repair. Truck ran great before doing the work. It started right up after but is skipping on #7 suspect bent push rod. They are coming tomorrow so i will pull it apart for that.
It has always started even with the skip. Went to start to pull inside the shop at night and i started around a few seconds of cranking and died. I tried to restart it kicked a few times but now start. Now it doesnt even fire. Pulled the ipr to check screen as icp was only 150 psi. Screen had a little crap on it but not much. Put it back in and went to start again and nothing. 150 psi after cranking for a few seconds. Noticed the oil pressure on the dash didnt seem to come up. I will try again tomorrow.
Truck ran great before doing the work. Now it wont even run.
