97stoker350
i was just wondering wat the max SAFE rpms are for the obs 7.3 or is the tach telling the truth to start getting out at ~3300?
I read somewhere that it isn't recommended that you pull it over 3000 rpm for extended periods of time because it can pull the piston in half.
would i pick much up from puting 910 springs and chromoly rods in?
Well, I have a simple set of 910's in. I have stock pushrods. I am the school that says if something is going to break, make it the pushrods, they are cheap. I have seen 4300 a few times. Still holding together.
Sorry, you have to find the breaking point for your self. I don't know, and I will not go out and find out for you.
BTW, your results may vary from mine.
Do you have a sound clip at 4300?????
YouTube Video |
That sounds awesome. Hows tunes are you running to get it spinning that fast
How much does having a race balanced rotating assembly help?
