OBS broken dash mount passenger side
teddy's6.0h
I need to know how to fix it! In between dash & door pillar. The vibrations are gettin annoying, I'm new to the obs game! Thanks.
Strokersace
Towanda, KS
Fabricate steel bracket. I've done it on quite a few. One some obs trucks it came factory with a metal bracket that was riveted to the plastic dash.
Sent from my XT1080 using Tapatalk
Parker, TX
You don't say what year your truck is, but check out the attached TSB> Cheers!
  • TSB 94-15-13 Passenger Dash Bracket.pdf
leojr
Thanks for the TSB!
Does this mean that 95 and newer have a design change and this isn't a problem with them?
teddy's6.0h
I never even saw the replys! Yes it's a 1995! & the tsb isn't valid anymore according to ford. Any one care to show their fabd up bracket idea with me?!
fordman67
evansville in
bronco grave yard also sells a copy of the ford retrofit bracket.
there are oe brackets out there but are obsolete so only old stock out there.
