Obs F350 4:10 geared D60 and 10.25 rear end
ghohouston
Lewisville,Texas
Pulled both axles out from my 97 F350 srw truck as I'm swapping to an 05+ suspension. Front passenger wheel bearing froze in place. It is probably going to have to be cut off. When I tried removing the axle nut, the axle nut socket just rounded out the 1/2" input on the socket. The stub shaft u joints should probably be replaced too since they have some play. Otherwise, the axles are good, and are the originals with 237k. The spring hangers, factory leaf springs, and all other factory Obs F350 srw suspension parts are for sale too, just ask. I also have a good used hub to go with the front axle that the buyer will receive. Asking $800 for the set. 4:10 gears. Craigslist link with pics attached below.
https://dallas.craigslist.org/dal/pts/d/dallas-obs-dana-60-and-rear-end/7397429102.html
