obs runs like crap
hayesmsr
My 97 csb starts and runs good for about 15 miles, then it "hiccups" like a miss then has no power. Doesn't matter what tune I change to they all run like stock. 160 cc injectors are about a year old, stealth srp1.1 hpop, 3" downpipe, wicked wheel2, hydra tuner, new fuel pump, new icp, just rebuilt fuel bowl. Any ideas or suggestions?
hayesmsr
Fuel pressure is about 65psi, the icp was from international. Haven't swapped the cps because I didn't think those symptoms matched. Uvch connections look good, no burnt spots. I just acts like the injectors are not giving it enough fuel. Almost like it goes into a default or defuel mode jut it's not throwing any codes
Isobaric
Dump water on the hpop when it starts acting up.
I'll bet you are dropping ICP.
ghohouston
Lewisville,Texas
Did you check fuel pressure under load? And I've had a cps cause random stalling and violent hiccuping.
hayesmsr
Fuel pressure was checked under load. Last time I checked hpop pressure it would hold 3100 under a hard load. Never heard of dropping water on the hpop though
Isobaric
It's a spr1.1 thing... Gallon of cold water contracts the housing and allows you to build pressure again.
hayesmsr
It's the srp1.1 hpop. I have a new cps that I will try when I get a chance. Really hope it's not my hpop, is stealth still in business?
hayesmsr
Replaced the cps this morning and I think that may have fixed it. It acted up once for a couple of miles but then cleared up. This time I had my torque app going and was able to get some readings. With my foot on the floor the ipr duty cycle was about 33%, hpop was 2400psi, and map wouldn't go above 14lbs. It's like it just won't give it more fuel. Could this be a bad map sensor?
ghohouston
Lewisville,Texas
You have a high pressure oil leak if your srp1 will only make 2400 psi
