Oh yeah
weazel
Elkview WV
Well I've been workin a deal with a guy for a while and this weeken it is going down he has a 04 f350 (much like myself) with a 10" lift that he uses as his work truck, he was tired of the hassle of loading and unloading it, so my stock setup is going on his and his 10" springs are going on the ox, I'm pretty stoked, only crappy part is the shop is a little tight with 2 super duty's in it.
Got it stripped getting ready to pull mine in now. Wish I had two lifts
Sent from in a ditch up side down and on fire with the wheels still spinning
weazel
Elkview WV
Yeah me too
Me getting swole with the Dana haha
Donor truck stripped
Mine front end stripped. Been workin our ass's off but slowly pecking away, 2 lifts would have been badass
weazel
Elkview WV
Are you swapping gears to? I just noticed that the donor truck had the diff cover off.
Not sure yet donor owner (haha) is still thinking about it, he has 4.56, I have 4.10, I would like the 4.56 .
He is dropping to 33" tires, 4.56 and 33's is not great for milage
weazel
Elkview WV
Shop is destroyed have a few little jobs come in and out slowing us down, front is almost done on the donor, had to run to summit in Reno to get new bushings for the leaf springs, the ones that where installed are thrashed, and leaf pack pins the rears where sheered off
Result of sheered pins
The culprit
Destroyed shop
weazel
Elkview WV
The front is up
Taking donations for tires the 32" ain't gonna cut it no more
weazel
Elkview WV
She is up, waiting on tires and shocks but the springs and steering and such is in.
Little taller than I thought it would be, I'm 6 foot and yes I know I look terrible but screw it I'm tired
weazel
Elkview WV
Looks good, post up more pics when you get finished!! :popcorn:
Will do, We still need to build shock mounts for the front, get tires, and I got some parts going to powdercoat
weazel
Elkview WV
More than likely 37x13.5x16 ss m16, finding a tire for a lifted dually becomes difficult because I want to keep 16" or possibly 17"
weazel
Elkview WV
My son was attempting to figure out how to get in
Triple H
What you need is an '05 XL grill and '05 Harley headlights.......
I sold my '04 and those parts are sitting in my garage needing a home......:D
weazel
Elkview WV
Need tires first, one day I'll swap it, but for now it stays
weazel
Elkview WV
Made some shock mounts this weekend,
ImageUploadedByTapatalk1369769386.804807.jpgImageUploadedByTapatalk1369769763.933679.jpgImageUploadedByTapatalk1369769793.387796.jpg
weazel
Elkview WV
Now I needs some tires, and ball joints, drivers side is pretty bad
Vizsla
"leaf pack pins the rears where sheered off"
I have seen this happen so many times(and on stock trucks).....,seems like it would be brought up often. Got to the point where I won't even use the supplied pins, easy enough to find grade #8 substitute instead. I've seen double pins with one broke, and the other severely worn. The AAL on my 150 came with #5 allen heads, straight to the trash, and shame on the supplier. Dangerous, and easily avoidable IMO. Good luck with the swap, very cool!
weazel
Elkview WV
The pins where replaced with some meaty bastards I got from napa, I'm friends with the guy that does the medium duty/18 wheeler stuff, he hooked it up.
The other truck that went back to stock didn't get blocks in the back because the pins became one with the block tried drilling them, but it didn't work out
