oil additive
blk350on20s
Hey guys. I need an additive like rev x but need it sooner than can be ordered. Is there anything that can be purchased at a local parts store that acts like rev x. Something that will clean the spool valves and help injector wise. Thanks. Ryan
motoxracer42
I don't think there is anything out there that can do what rev x can. Let me know if you want some lol. I just got a new shipment in stock.
windrunner408
I have found Evergreen's AR9100 oil additive to be just as good as rev-x so far and at half the price but you do have to order it.
blk350on20s
Appreciate it guys. If i cant find it locally ill be sure to call up and order some for my buddy. Thanks.
G Racing
Southeast Texas
The ar9100 works just as good if not better than rev-x. But you do have to order it. I try to keep some in stock. If you need some let me know.
Atsah
Maine
Really... Good to know.. How much is needed and what is the cost?
Pizza pig
MD
Im a loyal rev x user, you use more archoil than you do rev x. Depends on the situation, but saying one works better is a tough call!
windrunner408
Greg is right, that a less amount of additive is needed with rev-x vice AR9100 but the cost to treat the same amount of oil is about 40-45% less than if you use rev-x. I definitely won't argue that rev-x doesn't work because it most DEFINITELY does, but I think the AR9100 does just as good. JMO of course from what I have noticed.
windrunner408
YEP :whs:
It already KILLS me to be spending the $140 just for oil that I do to run Amsoil and then if I add $65 for rev-x, it just puts me over the top to be doing that every 5-6k miles LOL.
Fromojo
I'm not am additive hater, but what does it do?
I've seen YouTube videos, forum.comments, I looked at the msds sheet years ago and it was 50 percent potassium and the other half a secret ingredient. Banana oil?
I can you tell you first hand before it became widespread the Blackstone lab people said I had an internal coolant leak by noting the high ppm potassium. I ran it in my old truck equipped with a school bus engine, it didn't need any help with starting, etc. Just thought id try it
F-250-Owner
Masontown Pa/Maputo Mozambique
I also use AR 9100 and have used REV-X in the past, both are very good, but AR 9100 is just more affordable. My first order ended up being free because they sent me the wrong stuff, so I shippe dit back and they sent me double my order, plus aome fuel additive and gun oil..... very good to deal with
