Oil Cooler/Filter Relocate 6.4???
Halvy85
Bismarck, ND
Does anyone have the Donaldson filter and filter head numbers that match the stock system. I know someone posted it somewhere but I can't seam to find it now.
CAT35niner
NJ
Anyone running a fan on their air/oil cooler? Also is anyone using the van oil filter mount?
I know the MPD Cooler delete kit utilizes the van filter. They make a billet adapter so you can run lines to it. I've seen it mounted on two trucks. Looks pretty good. Uses the same filter as stock so it filters the same.
webb06
Seneca, MO
This is on mike corsillis truck
jimdawg185
I like my custom set up (RCD remote filter kit with Mishi air to oil cooler). My real issue is the oil has such a long way to travel that at -10 degrees it takes way longer than I like to build oil pressure. Im really not a fan for obvious reasons (also I am a tribologist and it makes my skin crawl and gives me nightmares). Anyone else notice this??
