brian89
I have not deleted the ebpv i dont think, not a hundred percent sure of what it is
i found where the leak is coming from, it is a big round piece directly under the fuel filter, im pretty sure its the hpop but judging from the pic on post #10 its not the hpop, its round and has a clip ring in it and it looks like the oil is leaking from the bottom where the gap in the clip ring is
Ok so how do i replace that seal?
HPOP Rear Plate O-ring Seal
This is the only sealing o-ring that is located behind the large disk and snap ring.
Please Note: A leak or seeping o-ring in this locataion is a very uncommon leak but it can happen. Before you order this o-ring, make sure that your leak does not originate from one of the discharge hoses, rear plug or non-serviceable plug and the oil has been pushed back to the snap ring lip from air flow over the HPOP.
Genuine Viton o-ring seal Viton
Any one tell me how a turbo seal is spraying oil under the hood....
Jesus...
It is a hpo oring somewhere... be it a line, be it at the pump, or the headplugs.... Fill it with oil, start it up, and see where it is spraying from.
