mudslinger02
Towards the frame. If you lay directly under the filter and look up at the bottom of it, you should be turning it counter clockwise
move the wrench to the drive shaft
Sawzall and a chisel.
Hate to say I told ya so, but; I told ya so.
How in the ***k does that even happen? Whoever did that shouldn't ever maintain anything on an internal combustion engine ever again. Or be allowed to drive.
Hate to say angle grinder 3lb sledge and a screw driverointlaugh:
wned:
sooooo... pretty much the same thing ?
2 days on an oil change??? This dude needs to be Jiffy Lube's best customer.2 days on the same thing ugh... that must've been a LONG two days.. glad you got it off!
I've had sticky oil filters, but dayum!!!! Ripped a few in half with the screwdriver method...never spent 2 days on one.
Had one on a C27 in a D10 that was so tight that the case of the filter started to slip on the crimp where it is crimped to the threaded part. Eventually took off the filter head, put it in a vise, cut the filter apart and used a chisel.
