Boost levels are lower than the Ex. I've heard that the Atlas 40 tune can do this but I have no experience with FICM tunes. The FICM tune was written after the SCT tune. Not even sure if there needs to be coordination between tuners on this one.
As to Hawgs point regarding the gears I'm still confused on this one. I'm running down the road at 2200-2500 rpm, which is about 65-70mph according to my GPS. Isn't this engine out of it's normal operating range at this rpm? Going to 4.30s or even 4.50s will make the engine spin even faster.
Try this...with your truck in park, rev the engine to 2500rpm...what kind of boost does it make? Should be FA.
Now put the truck in gear, hold the brakes hard, and try to rev the engine to 2500 rpm...now what do you see for boost? If you were able to even hold the truck from shooting forward, you should have seen over 20 psi of boost easy.
What I'm trying to show here, is that even at the same rpm, if there is no load on the engine, there is no drive pressure to drive the turbo, and no boost.
Bigger injectors fuel the same whether there is a load or not, so if the turbo isn't providing the extra air, it's all just going to be heat.
By using lower gears, 4:88's, the engine is reving higher, but it has less load on it then if it were running a set of 4:10's or 3:73's.
Less load on engine, = less boost = higher EGT's
BTW: With 4:88 gears, the driveshaft turns 4.88 revolutions for every one revolution of the ring gear in the rear end.
So if they swapped to 4:10's or 3:73's the engine would rev lower. (4.1 revolutions of the driveshaft, to one of the ring gear....or tire.)
Not trying to be a dick, just trying to help.
