I found this online from Ford
Motorcraft
![](//emoji.tapatalk-cdn.com/emoji2400.png)
MERCON
V Automatic Transmission Fluid (ATF) and Power Steering Fluid
* Premium-quality dual-use fluid for Ford, Lincoln and Mercury vehicles
* Can be used in vehicles requiring MERCON
V or MERCON
type automatic transmission fluid
* Provides excellent performance in electronically controlled automatic transmissions
* Manufactured with high-viscosity index, premium-quality, hydroprocessed base oils and specially designed performance additives
* Provides excellent shifting characteristics at high and low ambient temperatures
* Offers excellent thermal and oxidation resistance, as well as good low-temperature fluidity
* Provides wear protection and inhibits the formation of gum, sludge, lacquer and foam
* Provides protection against rust and corrosion
* Dyed red for easy leak detection
* Suitable for use as a hydraulic oil in a wide variety of industrial applications that call for an ISO 46 or SAE 20W viscosity grade hydraulic oil
* Not for use in applications where MERCON
SP, MERCON
LV, Continuously Variable Chain Type Transmission Fluid, Motorcraft
Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended
* Not for use in transfer cases
* Recommended by Ford Motor Company
* Available in cases of 12 one-quart bottles, four (4) five-quart bottles, six (6) one-gallon units and 55-gallon units
* Use of bulk fluid is environmentally proactive and bulk quantities are available at substantial savings
