Bugman
I doubt that that scanner is going to read any of the codes on a Powerstroke since Ford uses propriety software in their programing.
I keep harping on the WTS light just because if it doesn't come on then it means that there is a problem in the PCM or that the PCM isn't getting any power. Without power to the PCM the truck is going nowhere.
You also might want to check and see if there is power to the glow plug relay coil wires and if the relay is activating when you turn the key on. It should have battery voltage on one of the small lugs and a ground signal that will come from the PCM. If it doesn't get that ground then it is pointing towards the PCM and if you don't have power with the key on then back to the #22 fuse.
Your's wouldn't be the first truck that had the PCM taken out by the chip. If that is indeed what has happened.
