One piece/upgraded driveshafts
Josh@DirtyDiesels
PA
So after breaking my front diff and axle shaft last weekend it has got me thinking about how soon until I have drivshaft, u joint issues. I am thinking I want to do a one piece rear driveshaft with upgraded u joints. This possible on a CCSB? Also, with the front driveshaft is there a way to eliminate the double u-joints by the transfer case? Seems like more things to break and I want this truck to hold the power as reliably as possible. Give me some suggestions here!
under pressure
do you do any off roading ? the double cardon allows for steep drop angles when off road, big single joints are ok, just the balance and angles need to be spot on when talking about a short shaft for street, light trail use.
depending on the angle, t case drops and pinion angles may need adjusted, at least thats how we do them on old chevys and jeeps. not sure on the new stuff....
Josh@DirtyDiesels
PA
Not at all. Truck is lowered in the front and no block in the back. Its a pavement princess lol. Drive it on the street and down the track.
under pressure
sounds like a good candidate for one piece shafts and solid spicer U joints.
May even be some billet machined joints out as well, as there is in the hardcore off road world.
-just depends where you want the weak link.... like the greasable u joint... they snap before you twist that one piece shaft in two !
I would want a drive shaft hoop for a long single though.....
Josh@DirtyDiesels
PA
How will a rear one piece shaft work if the stock driveshaft mounts solid at the t-case and the rear diff? Not sure If I'm just confused about this stuff, but I really don't know much about driveshafts... And yes a driveshaft hoop will definitely happen
njjeep
Brick, NJ
There will be a slip joint at the end near the transfer case. Just look at any EC/SB or Regular Cab, they have a one piece rear shaft. Also the front shaft with the double joints is probably just as strong as a single joint. Plus you might have to change your front pinion angle to run one.
Axle Exchange - Fairfield, NJ
http://www.axle-exchange.com/home
http://4xshaft.com/
http://www.highangledriveline.com/
Those are two above are good drive shaft shops. On Pirate 4x4
lincolnlocker
Central Michigan
chromolly and 300m are available
live life full throttle
Demon
Alberta, Canada
I just recently swapped my rear to a one piece, as described with a slip joint near the tcase. It's really smoothed the vibrations out. Crewcab short box.
Sent from my HTC Desire HD A9191 using Tapatalk 2
Demon
Alberta, Canada
Around the $650 mark. extra heavy wall material. I was assured by the driveline shop That I won't break it sled pulling.
Demon
Alberta, Canada
It's steel tube. 1480 joints. Drive Systems Inc. (DSI) It's a local Calgary company, they do tons of industrial shafts mostly, for the oilfield, drilling rigs and highway trucks.
Demon
Alberta, Canada
Just shot a couple quick pics of it for you. We'll see how it holds up, but looks decent, I don't have any concerns with it at all yet.
