Opinions on wheel spacers?
Graham, NC
I'm wanting either 1 1/2" or 2" spacers for my rear axle to get the rear tires out even with the front. I've seen them from $40 to $300. I don't want junk bc this is a part that CAN'T fail. But I also don't want to pay $300 if I don't need to. Any thoughts here guys?
obspsd
I have 2 inch on the rear of mine and they match the front perfect. I got mine off ebay for 99$ for the pair
lincolnlocker
Central Michigan
have 2.5" between the dual's of my truck for about 80k now... no issues yet.... just make sure you don't get the made in china sh!t... i also got mine off ebay.. 145 for the two..
clayton
FSJ, B.C Canada
Got mine from fred goerske (sp?) They are hub-centric. They are not cheap though. Not something I wanted to cheap out on though...
Graham, NC
Ahhhh I see said the blind man! Thanks for the info! So should I go with hub centric since they're just for the rear or will I be fine with lug centric?
OBSWIZ
Wellington NV
We sell U.S. Alcoa 6061t6 billet aluminum, Lifetime warrentee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
To adapt '05 up to '04 and earyler:
2" spacers will work without needing to cut off your existing wheel studs but will result it the wheel moving out more as this will change the back space to 3.75"..rather than 4.5" thats stock.
We can get you 1.25" spacers but you will have to trim the studs shorter. But the back space with then be 4.5" and the rim will set like factory.
HaysKSFirefighter
Valley Center, KS
So you can hook me up with a set of spacers for my dually?
