The reason he bought the Ram is so he can drive around with the mirrors flipped up.
Billy T.
[email protected]
Billy T.
[email protected]
just measure the overall length of the bar right now, if it is 82" or under, you are ok.
Cutting the overlap down to the minimum 8" might be a good idea for future installers, mine rattled like crazy until I shortened the inside section of the bars. A ton of chatter bumps on these dirt roads doesn't help
Will do
You could've wrapped the inner tube with tape or used some RTV to dampen the rattle.
Billy T.
[email protected]
oh no kidden..There was a batch of bars where the tolerances were off causing the bars to rattle.
Billy T.
[email protected]
From the rear bolt to the washer/cup for the bushing on front mount....88 1/2".
Billy T.
[email protected]
not necessarily.. that is the entire point of "adaptable" length.. can fit many configurations. just needs a recommended 8 inches or more of overlap to be properly installed.. ouo makes a solid one piece bar too..So would PMF's be better then since they aren't a 2 piece??
