OUO ALA's install now creaking noise
CATDiezel
The OUO hiem joints are encased in a Teflon set up. No lube, lube like wd40 is bad.
Wd40 is NOT LUBE. It's a water displacement. Might as well use water if your going to use wd40 for lube! Penetrating oil is OK. But it's so light it will not stay is the problem. There is no replacement for a grease truthfully.
