Hey man could you explain a little more on this? Im not sure if its worded weird or the fact that Im still an idiot on this subject lol. Is the leveler something similar to ALAs? Or something used with ALAs? Sorry for the confusion just trying to learn what I can
Its a leveler used to lift/level the front of the truck and also allows for side to side adjustment if the truck sits uneven, which 99% do from the factory.
Its also able to be used with lift coils if you need to level a truck out with aftermarket coils.
The leveler must be used with ALA's or use shims to adjust for castor. Which is why the ALA's and leveler together are the ultimate combination.
Waited for the admin to send me her edited photos back and I'll post them. Its a pretty trick set up.
