RedRice589
What if your truck is too low???
Right angle drill.:thumbup:
You pansy a$$. I had all 16 holes drilled and mounts on in 30 minutes. Although I do recommend wearing a long sleeve and gloves for the bottom holes. Hot metal shavings in the palm of your hand and arm pit isn't the most comfortable working conditions. I strongly suggest spending some money on good drill bits. You only need 2 bits (1 for a pilot bit). It'll make your life much easier.
