I want to say yes on the shipping but I can't remember. As for your u-bolts, you should be good. The ouo mount will replace the factory ford under axle mount so you'll have plenty of length. Typically don't like to reuse ubolts, but I was real carful with taking the nuts off to not damage threads and so forth. They were the ubolts that came with my 8" fabtech lift. So again you should be good on reusing your ubolts. The long gusset is suppose to be a little stronger to support more horsepower, at least that's what ouo says. But I really just liked the way it looks on lifted trucks. Also there are a good bit of ouo videos on YouTube that'll show things better.
