P1316 code help !!
Smokin 6.0
Indiana
Thanks I feel alittle better know. This is the 6th set of 7.3 Injectors I've done and didn't do these any different than the last 5 so I was really confused on what might have happened
jaybuller
It's none of my business but it doesn't really matter who he got them from. Any manufacture out there can send out bad injectors. No matter if they are from the top rated or the worst rated it's gonna be a crap shoot when buying remains as some of the things like weak selenoids or whatever.( well unless your going with Pensacola injectors the. You can count on getting bad sticks!)
jaybuller
Make sure to update us when you get them back! I'd like to hear what the issue was the the injector guy lets you know....
Smokin 6.0
Indiana
No issue with the Injectors it was the valve cover gaskets. They were new and ohmed out fine and everything but I changed them just for the hell of it and everything was fine after
Smokin 6.0
Indiana
Yea that's what I thought after I went through it all 10 times I said he'll with this in changing the vcg's and problem solved
