juniort444e
All right, i finally got time to check my rear end and its not good. And i only have one vehicle right now. Soon to be another when ever i get the check.
I can not find a shop that will install my Detroit True trac, or even do maintenance on a rear end. And im guessing i will need a new ring gear from the chucks that i pulled off the plug. So my question is who do you know that will install and work on the rear ends that knows what they are doing. I dont want to pay a fortune but if it can be done right the first time relitively quick money wouldnt be an issue.
If you do know of a shop pm me the info or txt me with some info. I need this done asap. Thank you.
Cellular digits seven two four - 6 3 0- 5 nine 7 three
Thank you
Greg
Thank you
Greg
