piston bowl chamfer
powerstrokin44
I was wondering if anyone had a spec on how much to chamfer the piston bowl; such as angle, depth, overall width after chamfer? Any input would help.
Thanks.
Countrycar
Texas
I just found this article. But I would call Nate and double check with him as well. He did a set of new Mahle's for me. Are you putting a cam in your truck, or is this for future building plan's. I put Matt's stage1 cam in my engine build. It didn't have to have the reliefs cut for this cam, but I had them done just in case I decided to go with a bigger cam in the future.
http://www.dieselpowermag.com/tech/...t_driven_7_3l_ford_power_stroke/photo_07.html
powerstrokin44
Stock cam but im not doing valve reliefs im just going to chamfer the bowls since I work at a machine shop. I might as well since im doing my whole motor because I threw a rod.
