Bignbadbelair
- Joined
- Oct 22, 2013
- Messages
- 83
- Reaction score
- 0
Hey guys my truck one one day driving home from work was normal and I had heat threw heater until the water temp hit 180 degrees. Then the heater quit blowing hot air and the water temp steadily climbed to 204 then my heater started blowing hot air again and water temp came back down to 188. I got the truck home and checked the antifreeze level and I added 3/4 gal. Next day going to work it did the same thing. Checked antifreeze and it was full. Then I drove home from work and it did same thing again. What do you guys thinks going on? I never had this issue ever on my truck. I was wondering if it was a air pocket but though it would worked itself out by now. I am not sure what's going on. The truck has egr delete if that makes a difference.
