possible knock/ weird noise
jrex2506
OK found tiny shavings in my oil. plan on getting motor tore down soon. today I had to move it and noticed the motor doesn't seem to sound right. can't tell if there is a small knock or what. any ideas?
https://youtu.be/_ml5uOOjRvg
posted from middle of no where.
jrex2506
OK that's what I was guessing by the shavings. so I guess my cam is probably toast?
Richmond IL
Yes normally locks the roller assembly on the lifter then flatspots the cam as well as it cannot roll. Lmk if ya need anything we cary all valvetrain stuff in stock .
DEEZUZ
NO PUKESTERS
NWI
Lol, come on guy. I told you this in your last thread. Shut it down for good and rip er down!
jrex2506
OK taken motor out and starting disassembly. motor ran, had good power just shaving in oil. removed the oil cooler n found this in screen. other is just inside block. it ate a gasket from somewhere uploadfromtaptalk1457116957235.jpguploadfromtaptalk1457116969505.jpg
jrex2506
got other side to tear into the work on looking at my lpop and lifters. I was also running a dorman cooler which was my stupidity and have an OEM ford to go back in.
