Josh@DirtyDiesels
slightly less homo
Looks good, do you know the offset on those?
hmmm
lol. looks a lot better, wheels change any trucks look so much
slightly less homo
Ziptie. Ask me how how I know. Just pull the liner back.
Thanks man! Yea, -12mm, rubs like a mofo on the driver wheel well lol. I'm debating on what to do about it…might try a zip tie, I was gonna trim, but it won't be enough. I think I'll get an adjustable trac bar and center the axle, then trim how much I need, so I don't cut half of it out, then only need 1/4th cut with the axle centered lol.
Trac bar or trac bar bracket is the question now. If anyone has any insight, that'd be appreciated.
Future plans are carli coils and possibly a 1" spacer at most, if that will change anything. I kinda like the height now.
What wheels are those?
Garrett
you dont want to just do an adjustable track bar because the angle will still be off. a drop track bar mount is a better choice. did you do radius drop mounts as well? if not-the bump steer/road feel may get pretty bad.
No, just a spacer.
What all do I "need" to get it perfect?
Lol ok, let me go get some KFC lol, and drill it. Where'd you "tie" to? Frame? Or the cab?
Gotcha, I'll do that tomorrow. I MIGHT not make it though lol, the rubbing is insane lol
My 18x10s didn't rub. But I didn't do 35s because I'm a raging homo.
Sent from my HTC One using Tapatalk
Not much going on. Boss is letting me borrow an 03 this coming weekend, gonna swap turbos. Ordered new ic boots pink hot side blue cold side and a metal cold side pipe from riff raff.
Any turbo install tips will be much appreciated.
