CTFFEMT
- Joined
- Dec 17, 2012
- Messages
- 162
- Reaction score
- 0
after my rebuild including a melling LPOP, I got the truck to fire but I was reading 0 pressure on the dash gauge. I hooked a mechanical gauge up that read 10psi at idle (normal from what I remember). with a little throttle the pressure needle on the dash gauge would go to normal, then back to 0 at idle. I drove it a bit, dash gauge bounced like you describe, and after a couple harder runs it normalized.
So is the truck now running with a bouncing needle? If so, drive it a bit. Mine normalized that way. But my HPOP reservoir was filling. If your buddy's isn't then I'd advise against driving it.
Bouncing needle could be bad ground or air in the oil IIRC. Please correct me if I'm wrong.
