Pro Stock Powerstroke Mustang
Cutting-Edge Diesel
Newkirk, OK
Convertor should be done getting changed up tomorrow. New fluid is here to try and we will hit the track next avalible time. Really excited to see what it does with lock up.
Cutting-Edge Diesel
Newkirk, OK
We have ran type f, LAT performance synthetic, LE 1150 synthetic atf, and now we have some amsoil synthetic compressor oil that is known to work with these convertors.
521turbo
MICHIGAN
We have been running Mobil 1 0-20w motor oil. But no lock up clutch. The motor oil seems to take a lot of heat. I've heard good things about the compressor oil, it will take a lot of heat, with out braking down.
Cutting-Edge Diesel
Newkirk, OK
Just need our spacer for our torque convertor and it will be ready to run. Updates in the piston rings, breather set up and torque convertor. Everything mechanical on the car has been touched. Hoping for a full power pass. Currently have the lenco out inspecting the clutches.
Cutting-Edge Diesel
Newkirk, OK
We havnt seen the full Potential of ether set up yet so it's hard to say. Dan schied wants to see compounds back on the car but that was when we were considering a clutch. Single is so much easier on things.
Cutting-Edge Diesel
Newkirk, OK
Went to the track this past weekend with a new turbo set up and managed 148mph in the 1/8th mile. Convertor is still too loose off the line and 60' suffered resulting in a 5.33 1/8th mile ET. 148 is 4.80 range with a 1.20 60' like we have done before. Boost braces started to rip out so that's the only pass we got. Will head bsck out Friday.
148mph is right where I need to be for a chance at setting records in prostock class.
