Problems gettin it launched !!
swinky
Eastern, Nc
Or just give idp a call, torque converter sounds like the problem but it would be nice to rule tuning out.
powerstrokedkid87
New Jersey
Who's tunes?
So if I'm understanding this right... you can't get it to build boost on the line, but it's still pushing through the brakes?
4.88 sounds like a pretty tall gear. I would of stuck with like a 4:10 for those 37's. Most of my buddies who ran 37's ended up going back to 3.73's.
this......we run 3:73s in the red truck
check icp, also check boost leaks as mentioned above, I can build 15-20lbs of boost in the brake all day long, its a little smokey, but turbos light hard after that.
I would also think with the HO turbo you should see more that 30-35lbs. makes me think still have boost leak somewhere
BlackMagic06
Canada
Finally finished work for the week and can dig into this thing properly. Thanks VERY much guys for all the ideas and hints !!!
