Vader's Fury
:whs:
shane when are u planning on having it done ?
I figure spring 2013 to be honest. Hope the current engine lasts that long.
Maybe there is something i dont know or maybe this is a dumb question, but why so long? Are you out of town or are you having to wait on parts?
What kind of power are you running on the current engine, that wouldnt be cool if it went down before the other was ready
Mike I've heard that same statement from every side of the fence, I'll be the judge on what's superior and what's not.
Since my post got deleted I'll ask again. What all changes have you made to this build? I know now your saying sub 600?
The build hasn't changed much. My current engine in the truck has been put back to stock that's all. The build list for my actual build is as follows thou.
Build List
6.4 Powerstroke Engine
Bullnosed crankshaft
H-11 main studs
Ford bearings, gaskets, seals
Carrillo forged rods
Ford STD pistons with lip removed and hard coat anodized, comp ratio 16.5:1 from 17.2
Custom Age 625 head studs
Elite stage 2 heads - 2mm bigger valves, 160lb springs, chromoly locks and retainers
RCD aluminum oil pan
Elite 150hp and 110hp nozzles
Elite twin K16 pump kit
Elite stage 2 lpfs
Brand new stock hpfp in valley
Colt Cams camshaft
Elite ported fuel rails
Ported and ceramic coated 6.0 manifolds
Elite custom up pipes with wastegates off both banks - ceramic coated
Elite Max Power turbos - polished housings and ceramic coated exhaust side using a 1.28 housing as well
CFM intake elbow
Elite Twin Tube IC pipe designed to clear twin pumps
BD Diesel blow off valve on hot side pipe
3 Tial MV/R wastegates - 2 from before the hp turbo to down pipe and 1 from before the big turbo to the downpipe
Elite ported intake manifold
Elite high flow intake kit and battery relocation
Elite intake piping - all powder coated
Spearco intercooler
Dieselsite IC boots or Elite's boots
AMS1000 digital boost controller for main gates and regulator for 3rd gate
Tuning unknown, thus far Eric on SCT or someone on my old spartan
Custom airbox by Elite Diesel
Elite Diesel stage 2 pushrods
5R110 Transmission
Elite billet flex plate
NADP trans with TCS billet shafts, hubs, drums, and planetary's
Suncoast HD converter with lowest stall option, 2500 stall
3.55 gears
Detroit locker rear, ARB front
Suspension
RCD 4 link front suspension arms
OUO weld on long gusset traction bars
Shocks are unknown
Brakes
SSBC front calipers
EBC slotted rotors
That's the build as of today and it shouldn't change much.
So you reused the block and the timing chain?oke: I have to say that would be the most comprehensive engine build I know of on a 6.4L. That should be a hell of a truck right there.:rockon:
Wouldnt you want the waste gates from the up pipes to gate around the high pressure turbo to spool the low pressure turbo, instead of to the down pipe.. Seems like a lot of energy wasted there.
