Stroker04
Why are you swapping them out?Yeah an 11 blade
Sent from my LG-D950 using Tapatalk
Mpd recommended it. The 11 blade is a Chinese pos with no r&d behind it apparently.Why are you swapping them out?
Interesting. Glad I didn't buy one then. LolMpd recommended it. The 11 blade is a Chinese pos with no r&d behind it apparently.
No Charlie I bought it with the 11 blade. I'll be sure to let you know of any egt drop/gain as well as times. Just by looking at the 11blade it looks like it won't move a lot of air. 11 blades on a 66mm puts the blades very close together. I'm expecting a small increase in lag but better flow up top. The guys at mpd told me to get rid of it.swinky...
just curious if you experienced bad results immediately after swapping to the 11 blade? I know you had a bad exhaust leak and many other problems. Just curious if they were related.
We usually sell the 7x7 billet wheel... but it is good to know if the 11 blade is really that bad in the s366.
Thanks for the clarification. I look forward to your results.
Billet 7 blades are usually 200-400.How much are the billet wheels from you guys Charlie?
It would be nice to see cheaper rods out there
I'm guessing they'll be in the $1700 range. How's your setup doing? any track times?
Damn that sucks. I guess I'm doing hybrids.Truck is currently down because I've literally broken all the springs in the injectors. I should have new 300/100 hybrids sometime this week so it should be interesting. My local track opens up in early April so I will definintly be running it here soon.
Dynamic dieselWhich company is going to make these rods?
Dynamic diesel
Hmmm... I just started looking into getting rods made for around the same price range.
Do u know how close they are to going to market? I might skip my endeavour if they are close and are going to move forward on the project.
Release date is 7-1-15 according to them.Hmmm... I just started looking into getting rods made for around the same price range.
