BWCbuilt
when you get it done you can be warm again though....
My buddy is a mechanical engineer im gonna see if he will rig me something up
Mechanical Engineers can do pretty much anything. :demon:
triple nickle FTW
no need for coils with this setup, all parts available at Radio Shack...(at least they used to be).
The issue I see with the 555 chip setup above is that you can't just flip a switch and have it keep firing the spark plug.
No - but you can use a second 555 chip to generate a PWM signal to trigger that circuit.
Or the 2nd 555 in the same IC (556).
Whoa! - lets not get too crazy now! LOL
So no 558?
I still think the easiest way to get the spark plug to, uhm, well, spark, is to use a single 555 timer, a transistor, a capacitor, and 5 resistors, like this:
As is shown & explained a little bit here: http://www.capturedlightning.org/hot-streamer/kv2/kv2/hv/icoil/index.htm
I know for a fact that those hurt.
Prolonged exposure may cause loss of bladder control. Don't ask.
i have no clue wtf is going on.. this line goes to that circle then that line goes to the square.. so confused..
