race truck's new setup
SEABEE08FX4
Montgomery TX
So how are you going to torque these down on bare aluminum? There is no pressed in steel insert for the bolt holes. In fact I don't see any inserts in the heads or are these not final machined yet?
SEABEE08FX4
Montgomery TX
These probably require twice the torque of the ones you have dealt with. Maybe that's why he is asking.
Can't wait to see how it runs. Looks great.
Sent from my DROID BIONIC using Tapatalk
That's exactly it, depending on the studs used torque yeild will fall between 250-325 ft lbs. if they are not final machined it shouldn't be an issue they just need to be drilled out and have inserts pressed in.
Boostfed
In the shop at Rudy's
None needed, torque like factory as per empire today. I was concerned with the same thing, apparently they're thick enough to take the torque im guessing.
907DAVE
AK
Sorry if I missed it, but is there no coolant flow through those heads?
91turbogsx
Gardner MA
After looking at the Cummins aluminum heads available it looks like they have steel inserts pressed in. Granted they are not as thick as these. Stock torque specs I wouldn't worry about it but 250-325 lbs/ft I could see the cause for concern.
I sure they will be the first testing these out to see if it holds up anyways. Has Empire actually ran these heads on an engine yet?
Boostfed
No, we are doing the testing.
Durham, NC
imelmo
This may be a premature question, but when are y'all gonna be trying to hit the track with it?
