Rear axle spindle nut
CT9AIX
MA
That looks like it. I've got the OTC socket at the shop, I'll double check the part # on it tomorrow and post it up
KR69IDI
Thanks guys. I thought it was right, but wanted to be sure. Any idea what side is LH threads? I'm pulling the driver side hub.
KR69IDI
I ended up pulling both rear axle hubs. For the record... The socket listed above is correct and works great. The drivers side is reverse thread and the passenger side is RH thread. If anyone reading this would be doing this as well, make sure you have replacement hub seals on hand (I did, thankfully). Both of my seals pulled apart when pulling the hubs off so there is zero chance of reassembly without replacing the seals.
