justintimemoto
I had bad wheel seals and i changed them about two weeks ago. put 75-140 with the friction modifier in it. Driveing down the thruway last night my rear end started to tick click. I put it on the jack stands and it wont do it with the wheels off the ground. So i put it back on the ground and it does it only while the truck is on the ground. If this helps at all when i pull a trailer the truck will start to shudder and shake when i take off or go up a hill when its under a load and i will have to let off the gas. Any help will be appreciated it sounds like its coming from the right side. is there a way to check if the bearings are bad i shook the tire back and forth and there is no play at all. Am i looking at a new rear end?:/ Thanks
